EFI Live - Forced Induction - 2 Bar Sensor
Old Feb 13, 2011 | 05:07 PM
tatasta's Avatar
Default EFI Live - Forced Induction - 2 Bar Sensor
I am running a P1SC at ~ 7lbs. I have maxxed out my MAF and will go SD soon. I have a 2 bar MAP sensor that I need to install. What will i need to do from a tuning standpoint to use this sensor and to map it in my COS with a boost VE table?
Any help will be appreciated.
Thanks
Old Feb 14, 2011 | 04:34 AM
TunerGuy's Avatar
There is a very good write up in their COS instructions on how to do this, step by step
Old Feb 14, 2011 | 01:16 PM
tatasta's Avatar
Thanks!! I should have thought of that.
Old Feb 15, 2011 | 09:11 PM
joecar's Avatar
There is a MAP scaler that has to be set for the 2-bar MAP, when you look at the parameter the description tells you what value to set it to... what TG said.
Old Feb 17, 2011 | 07:42 PM
tatasta's Avatar
Thanks joecar and Tuner Guy.
I found the info on EFI Live.
