VE pid in EFILive 6.3
Old Feb 13, 2004 | 01:46 PM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
Default VE pid in EFILive 6.3
Are the numbers reported under the VE PID in v6.3 suitable to plug into ls1edit?
Old Feb 13, 2004 | 02:06 PM
Bink's Avatar
Are they in Edit values or % (VE)?
Old Feb 13, 2004 | 02:42 PM
deezel's Avatar
Possibly... you should check a couple of things first. Make sure the PID is using the correct displacement for your engine - I think 346ci is the default value. If your different you need to edit the calcpids file.
EFILive reports %VE, but the tables in Edit use %VE*30. (So 100% VE = 3000 Edit units, 50% VE = 1500 Edit, etc.)
