03 Cobra with LSX413 tuning question
Old Feb 18, 2011 | 03:06 AM
turboed2000's Avatar
Default 03 Cobra with LSX413 tuning question
Ok so here is a run down of what it is and the problem Im facing.I have an 03 Cobra with a Lsx 413 and a powerglide. Iam using EFI Live with a 2002 ecu and cos#3. It has a single gt4780, 160# injectors, 3 bar map sensor Sd tune, Aem injector driver, 50# base fuel pressure, 23# of boost on e85. All the way from 3k-5800 rpm the air fuel is 11.50 steady and fuel map is good. But by 6000rpm Im at 13.0 and rising out of control. It has 73-75# of fuel pressure and I started adding fuel to my fuel map. I added 15% with no changes to afr. I have went as far as maxing out the fuel map with no luck.
Any suggestions would be great. Ill try any thing at this point.
Old Feb 18, 2011 | 06:20 AM
xBRadX's Avatar
What's your injector duty cycle? Can you post up a log?
Old Feb 18, 2011 | 12:28 PM
My duty cycle is 80%. I cant figure out how to post a log. The car use to have big stuff and would rev to 7500 with no issues. Same everything just went to stock ecu with the aem driver box.
