Replaced Alternator, now AFR's are lean...
Old Feb 18, 2011 | 12:58 PM
Simplex Effect's Avatar
Default Replaced Alternator, now AFR's are lean...
I had my LS1 RX7 retuned a few weeks ago and we had a low voltage issue.
HPTuners wouldn't flash the PCM so we put a jumpbox on the battery. It flashed the PCM and my WOT AFR was 13.0
Yesterday my Alternator died, so I replaced it and now my WOT AFR is 14.0-14.3
Just wondering if this would normally happen due to voltage issues or something else happened during the meantime.
Old Feb 18, 2011 | 01:32 PM
Sweet_SS's Avatar
Does it cycle from 14's at all? Just wondering if your sensor crapped out and is at its default max setting.
Old Feb 18, 2011 | 01:37 PM
Yes.
The lowest it will drop to is 14.0 though. AEM UEGO or EUGO, however its spelled.
Old Feb 18, 2011 | 02:24 PM
Sweet_SS's Avatar
Well my old UEGO, would stay in the 14's when the sensor died. I spent hours trying to fix my tune the first time it happened. Then I came to the realization, that my air fuel wouldn't change after adding any fuel.
Old Feb 18, 2011 | 09:43 PM
Mine only has maybe 6-800 miles on it.
Old Feb 19, 2011 | 10:19 AM
Sweet_SS's Avatar
6-800 miles really doesn't matter. It all depends on the fuel you use. I could only get a couple hundred miles...if that out of mine. This was due to using leaded fuel
Old Feb 20, 2011 | 10:38 AM
Speed Freek's Avatar
I had a brand new sensor fail within 2 months, age is irrelevant..
Heres a trick that sometimes works..
Remove your Wideband sensor, get a mapgas or propane torch and heat the end of the sensor until it is glowing hot, sometimes this will burn off the crap that is causing the fault, worth a shot..and if it works you saved yourself $80 on a new sensor.
Old Feb 21, 2011 | 08:49 PM
Eagle02's Avatar
THIS^^^
Have you tried to recalibrate the sensor in open air?
Old Feb 22, 2011 | 06:22 PM
Drove the car last night and today, my AFR is getting closer and closer to my 13.0
Sometimes even held a 13.0
Its running alot better the more I drive it.
