Will removing the AIR tubes require programing
Old Feb 14, 2004 | 04:28 PM
Kurt D's Avatar
Question Will removing the AIR tubes require programing
If I remove the AIR tubes and hoses, but leave the pump hooked up will it trip a SES light? I will be running O2 sims.
Old Feb 15, 2004 | 10:46 PM
Kurt D's Avatar
T T T
Old Feb 15, 2004 | 10:54 PM
2xLS1's Avatar
It will eventually set a code. O2 sims have nothing to do with the AIR system. If you are going to pull the tubes and hoses, pull the AIR pump fuse. It can be kind of noisy running without the hoses on it.
Old Feb 15, 2004 | 11:53 PM
Kurt D's Avatar
See that's what I was wondering. I'm sure if I pull the fuse the SES light will come on eventually. My theory was leave the pump hooked up, what's a little more noise at start up for a few seconds, I already have long tubes and a loudmouth catback. PCM sees it and thinks its working. Rear O2 sims say cats are lit off and working (always) so PCM thinks AIR system is working. No SES light. OR is that too good to be true, lol.
