please help
Old Feb 27, 2011 | 09:19 PM
kyles06crew's Avatar
Default please help
Ok this is what i have, I bought this car and it came this way 98 camaro fully built 5.7 ls1 turbo 400. I started the car for friend turned it off and the next day I went to start and it cranked but wont start. Its getting spark ,fuel, fuel injectors are getting signal. tried different pcm same thing.So what else should i check. Its like timing is off or something. Help please.
Old Feb 28, 2011 | 01:59 AM
elwood2's Avatar
Do you have a multi-meter? Check ALL fuses inside the car and under the hood. If you don't have a meter you'll have to pull each one and visually inspect each one.
Old Feb 28, 2011 | 07:37 AM
I have checked all fuses and they are all good.
