Just to be safe
Old Mar 8, 2011 | 05:48 PM
JOSH13's Avatar
Default Just to be safe
Every since I put my transmission and stall back in I have not been able to get it to lock up. I wanted to check and make sure that this is in no way a vcm tuning problem before I pull it AGAIN. Any kind of hints or tips would be great. I just don't know why it will not lock up, both have been rebuilt. I just want to make sure this isn't a computer problem before I do all the hard work
Old Mar 9, 2011 | 11:50 AM
flame's Avatar
I saw in your other post you have HP tuners so using the scanner you should be able to command the lock up on. If it works then you know its a tune issue.
