terrible gas milage
it has no codes showing and smells very rich when just parked. it has cut and extendd 02 sensors and im woundering if i should just buy the longer vette ones that are better but just wanted a second opinion thanks.
The O2 sensor has a 1 Volt working range. If you cut the cable and elongate it you are adding resistance (Ω) to the sensor's circuit. Also, the air reference may be disturbed.
So, the millivolts signal the sensor is sending is now wrong. It won't trip DTC codes, but AFR won't be stoich anymore because the added resistance will cause the PCM to see lower millivolts than real. If the air reference of the sensor was blocked or disturbed, the signal may be even worse, leading to very low mileage.
Lower millivolts=lean, so the PCM will enrich the mixture. How much? it depends on how good are the splices of the cables. Bad unions have very high resistance.
You need new sensors. Buy a set of harness extensions, they are like $30 each, that is the correct way to elongate O2 sensors.
and frost im tryin to stay on justin(bad6as) to get him back down there asap to get that car finally finished and not take a year to get down there the next time lol
and i was the guy with the glasses when us 3 came down for the tune
