Map sensor symptoms p106 please help
If it's the map U R referring to, first, I'd check the wiring, then the voltage, port sealing where the sensor is mounted.
Key/engine off.. what does it read? [KPA].
Running idle? [Big cam could skew normal readings..[Lower]
