part throttle stumble
Old Mar 12, 2011 | 09:49 AM
79lsz's Avatar
Default part throttle stumble
I recently installed a 5.3(L33) with 5.7(LS6) accessories, intake, headers with computer and harness from LS1. When I first start it, it will run fine with good throttle response. The problem is when it gets up to temp. it will still idle fine, but at a steady part throttle, it stumbles, and comes back, like galloping. fuel pressure at rail is steady at 60 psi, I've checked for vacuum leaks by spraying carb cleaner around every thing with no results. I also have a wideband o2 sensor and gauge that is telling me that it is running really lean at idle like 15.5-16 afr, maybe higher, only reads to 16. No codes are being set either. So my guess is that i need to get the computer retuned because of difference in displacement? Sorry i dont have any data logs because the geniuses at painless sent me the wrong software I have searched this, but haven't come up with same situation. Any ideas/opinions?
Old Mar 12, 2011 | 11:51 AM
01ssreda4's Avatar
By the sound of it the tune is likely the problem. I bet the problem will show itself.
Old Mar 12, 2011 | 10:19 PM
BlueThunder2's Avatar
If it's only doing it a part throttle, but not doing it at idle or wot, that tells me that you have a bad O2 sensor. Try replacing them or turning them off and see what happens.
Old Mar 13, 2011 | 01:53 PM
79lsz's Avatar
OK so I unplugged the wideband, and the problem went away, plug it back in and it does it again. So is it safe to say that the o2 sensor is bad? It only has about an hour of run time on it in the garage. So with this unplugged does it mean that it is running in openloop? If so, is this a bad idea? Well, either way Im sure that I need to get a tune. Oh btw, when I plug the sensor back in, the wb is reading in the upper 14s but soon maxes out the gauge and does its stumble thing again.
Old Mar 13, 2011 | 08:17 PM
Yes, when the O2 is not plugged in, it runs strictly off the computer program. When the sensor is plugged in, it makes adjustments iaw the O2 sensor to try to keep the afr at stoich. So, it makes me wonder if the sensor is bad, or not calibrated. Or if the program is not recognizing the wideband properly. ......interesting.
