what are these DTC's from?
Old Mar 13, 2011 | 11:09 AM
cals400ex's Avatar
Default what are these DTC's from?
Here is a list of the DTC's that HP tuners gave me. I am getting a service engine light and I am not sure why. The MAF sensor is deleted and I am running a 2-bar map sensor with my procharged setup. Any suggestions?
[PCM] P0103 - Mass Air Flow (MAF) Sensor Circuit High Frequency (Pending) (Current) (Immature)
[Restraints] U1000 - Class 2 Communication Malfunction (History) (Immature)
[Restraints] B1001 - Option Configuration Error (History) (Immature)
[Restraints] U1016 - Loss of Class 2 Communication with VCM (History) (Immature)
Continuous Tests
Misfire: Complete
Fuel System: Complete
Comprehensive Component: Complete
Once Per Trip Tests
Catalyst: Complete
Heated Catalyst: n/a
Evaporative System: Complete
Secondary Air System: Complete
A/C System Refrigerant: n/a
Oxygen Sensor: Incomplete
Oxygen Sensor Heater: Incomplete
EGR System: Complete
Old Mar 13, 2011 | 07:01 PM
joecar's Avatar
Sounds like the SDM/SIR/airbag module has been unhappy or was otherwise failing.
Old Mar 14, 2011 | 05:00 PM
cals400ex's Avatar
i wasn't sure which of these codes would actually cause the SES light to come one...
Old Mar 14, 2011 | 05:08 PM
foff667's Avatar
LS1TECH Sponsor
the maf code is the only one that will set a ses light.
The other 3 are common after reading/flashing the pcm and are usually nothing to worry about.
