scanner says......?
Old Mar 19, 2011 | 04:36 PM
LigHtEmUp01's Avatar
Default scanner says......?
i have a 95 camaro and the scanner is paying 36 high res failure. what does this mean?
Old Mar 19, 2011 | 07:51 PM
Smokeshow_2006's Avatar
probably time for a new GM opti.
Old Mar 19, 2011 | 09:04 PM
flintwrench69's Avatar
Yep. I would check the electrical plug that goes to the opti. I have seen them very corroded & blue in color from all the corrosion. If so, you will need the pigtail for the opti as well.
Old Mar 19, 2011 | 10:47 PM
From one of the OP other posts, I gather he's recently replaced the opti. Im guessing he didnt use a GM part.
