2002 Malibu VATS delete
Old Mar 21, 2011 | 05:08 PM
davidws6's Avatar
Question 2002 Malibu VATS delete
Only choices in HP Tuners is Serial and PWM on the vats menu.
I read a post on HP Tuners forum that said to change it to the other and turn off the ses light codes.
Did that and the car will run for 5 sec. then shut off.
Anyone know on how to disable ?
Thx.
Old Mar 22, 2011 | 02:20 PM
CalEditor's Avatar
Thx.
read this
http://www.monodax.com/forums/tunerc...-problems.html
Old Mar 22, 2011 | 10:25 PM
foff667's Avatar
LS1TECH Sponsor
Or this http://www.hptuners.com/forum/showthread.php?t=12399
I've never had a customer say it hasn't worked just by setting the switch & dtc's up correctly, but if you do have an issue its as simple as emailing support with your stock & modified files and a scanner log while logging the vats status bit.
Old Mar 24, 2011 | 05:54 AM
davidws6's Avatar
I'm pretty sure I had it setup the same as in the above link.
I'll try the proceedure again and go from there.
Thx !
Old Mar 25, 2011 | 08:29 PM
a338566's Avatar
same issue here, how do i get a scanner log while logging the vats status bit, went into vcm scanner and didnt find anything for vats
Old Mar 26, 2011 | 08:43 AM
jay_lt4's Avatar
are you still using a bcm ,, if yes,, you can just put a 2.2k-ohm resister in the wiring for the pass lock
snip the wiring for the pass lock/vats and put the resister between the black and yellow wires going to the bcm,, then just do your 10 min re-learn
i do this all the time on cars that have a bad ign cylinder/ pass lock sensor
Old Mar 26, 2011 | 09:36 PM
a338566's Avatar
how do you do a 10 minute re learn?
Old Mar 26, 2011 | 09:48 PM
jay_lt4's Avatar
crank the engine it should start and die,, leave the key in the run position for 10 min, the security light should go out. turn the key off then try to start the car
on some gm vehicles you will need to do this 3 times
