NO Ltrim OR Strim readings???
Old Mar 30, 2011 | 11:32 PM
vwajda01ta's Avatar
Default NO Ltrim OR Strim readings???
just got my car running after replacing a head gasket and now on my hptuner scaner i have no LT or ST readings thay just stay on 0 looks like no fuel corrections are being made.. My O2s on both sides are working i can see the numbers moving on those and so is my maf readings.. anyone have any ideas??
Old Mar 30, 2011 | 11:49 PM
jay_lt4's Avatar
are you going into closed loop? any dtc's
Old Mar 31, 2011 | 07:51 AM
redtan's Avatar
I assume you had your battery out while doing the heads? If so then your computer will need a little bit of time to learn the new trims before you can see them.
Otherwise, something in your tune is now commanding open loop all the time. Maybe your water temps are not getting up high enough for closed loop to kick in if you changed the thermostat.
Old Mar 31, 2011 | 11:55 AM
vwajda01ta's Avatar
Found prob forgot to plug in a O2 sensor found a dct as per jay said thanks for help every thing ok now
