Maf?
Old Apr 1, 2011 | 05:15 PM
LS1CMR's Avatar
Default Maf?
are larger factory MAFs interchangeable with a f-body , example MAF out of a 2008 truck with the 6.2l to a 2000 f-body with a 5.7l
Old Apr 1, 2011 | 08:33 PM
Snapps's Avatar
Yes, an for example a 85mm maf will have the IAT built into the maf so you will need an adapter harness, which you can find via lingenfelter performance as well as other places, but most likely you will need a tune to reclaibrate the maf tables when using anything other then your stock maf, keep in mind that the stock maf will support up to 500 hp, so depending on your mods or future mods you might be better off spending the money elsewhere. Hope this helps
