Need help with two wires!!! Please...
Old Apr 2, 2011 | 11:57 PM
Dave-1970's Avatar
Default Need help with two wires!!! Please...
Background info: 06' truck harness, 24x, converting to stand-alone with cable throttle body using 04' GTO PCM. Question: Truck PCM has Blue pins 19 (ignition 1 voltage), and 75 (OFF/RUN/Crank voltage) both pink wires as keyed power to the PCM I assume... Now, the GTO PCM pin-outs only show Blue 19 in use as Ignition voltage, Blue pin 75 is Not Used??? Does the GTO PCM only have one keyed ON wire?? Should I get rid of pin Blue 75?? Thanks in advance!!!
Old Apr 3, 2011 | 12:30 PM
LS88FoxBody's Avatar
I just looked it up on All Data. I see what your seeing. But I don't really know how to answer you. I'm running 03 Harness , 03 PCM with 04 GTO OS. And mine is wired as the truck harness. So not sure if it helps or not...
Old Apr 3, 2011 | 03:24 PM
Dave-1970's Avatar
Thanks for the reply! So you have key power going to both Blue 19 and 75?
