Help.. Bank assignment table ?
Old Apr 8, 2011 | 02:13 AM
mike06tork's Avatar
Default Help.. Bank assignment table ?
dose sumone knows where can i find the bank assignment table? I need to find this table because i installed the 24x LTX EFI Conversion system on a 1995 camaro im currently running a 2000 LS silverado PCM, i was told the LS1 engine has a diffrent firing order than the early SBC and LT1 engines. Specifically, cylinders 2&3 and 7&4 have to be swap around. So for proper close loop operation, bank-to-bank fueling can be corrected through the PCM calibration by assigning the appropriate injector to each bank. i was told the easiest solutiuon is to load a calibration from a 2001-2002 Express Van and then copy/paste the injector to bank assignment table values into my LS-bsed calibration. sound easy but i cant find this tabe all i have found is the firing order so can anyone help me finding this table... thanks
Old Apr 8, 2011 | 06:13 PM
joecar's Avatar
LT1: 1-8-4-3-6-5-7-2
LS1: 1-8-7-2-6-5-4-3
You could re-wire the coil and injector sub-harnesses to match your FO...?
Old Apr 15, 2011 | 11:34 PM
bullygoat's Avatar
Engine>Fuel>General>Injector Control Column, injector bank select button.
