ANOTHER SET BACK, wire harness??????
Old Apr 21, 2011 | 05:42 PM
turbotrans am1's Avatar
Default ANOTHER SET BACK, wire harness??????
I sent what I thought was a ls1 harness off to get reworked, take out MAF, rear O2s, and all the stuff that wasnt needed. Turns out It was a truck harness. Will I run into problems if I use it? Everything plugs up exept the O2s and I fingured I could just buy O2s for a truck.
The guy who worked on the harness said i would just have to use a pcm from a truck. Is he right and will I loose any tunabilty using a truck pcm rather than ls1 pcm.
Any info would be appreciated
ps: the car is a 94 TA with 370 LQ9, gt-88 turbo, reverse truck manifold set up.
