Vats bypass???
Old Apr 23, 2011 | 01:57 AM
LS1aiden's Avatar
Default Vats bypass???
I am trying to bypass my VATS system my key number is 13 and I need to know what type of resistor do i need voltage etc... thanks, any help will be appreciated.
Old Apr 23, 2011 | 02:21 AM
Anthony Williams's Avatar
Just get a multi meter and read the resistance across the keys resistor, Radio shack carries all of the values used in GM keys. The resistor can be either solderd or spliced in.
Old Apr 23, 2011 | 02:58 AM
LS1aiden's Avatar
mine is between 7.2 - 7.8 resistance.
Old Apr 23, 2011 | 03:09 AM
Vats = http://www.vatskey.com/vats/lostvatskey.htm
Just use the formula to fine the resistor you need, Caddillac forums is where I foun a good write up on how to bypass it. did it on my neighbors 1994 Sedan Deville, worked perfectly.
Old Apr 23, 2011 | 11:12 AM
LS1aiden's Avatar
alrite thnks, imma go try it and hopefully i get it right the first time.
Old Apr 23, 2011 | 01:25 PM
LS1aiden's Avatar
Finally got her started, but i didnt use the resistors cause i couldnt get them to work but anyway the problem was when i had replaced the ignition and got a new key made, I tried to put the key in but it wouldnt fit so today i just got fed up with it, so i took a deep socket and tapped the key in till it was flush, turned they key and car started. So to anyone who might have this problem in the future and thinks its the key you have to make sure the key is all they way in the ignition or the car wont start!
