problems need help
Old May 15, 2011 | 06:32 PM
Frametwista's Avatar
Default problems need help
I don't know if this should be asked in this forum but I'm going to give it a try I'm using a lingenfelter conversion box I have a 98 ta with a ls2 in it with a 58 tooth wheel.Now I've ran this all last summer no problems but now it cuts off and wont start up sometimes 30min sometimes hours but eventually it starts have anyone had problems with their box malfunctioning thx in advance it threw some codes first crank then camshaft sensor I changed both still have the issue
Old May 16, 2011 | 12:17 AM
skypuppy99's Avatar
How old is your gas in the tank? Just though I ask.
Old May 16, 2011 | 08:41 AM
Old Geezer's Avatar
Fuel psi is? [Dying pump]
Data logs would help.....
Old May 16, 2011 | 09:59 AM
BlueThunder2's Avatar
I had a similar scenario with a '99 T/A. Would run great when it would run. Might start 10 times in a row, then not start for seconds, minutes, hours, or days. Basically did what it wanted. Started out by checking for fuel pressure. Had good pressure. Next checked for spark....no spark. Replaced crank position sensor twice....same thing. ohmed out wires for crank position sensor...checked good. Replaced computer.....no more problems.
