3k stall, low rpm knock!? Had the stall about 2 years, input shaft on tranny is going bad - but can't afford to rebuild yet. That said, is there anything that has worked in the past for making the engine not knock/rattle/whatever when low rpm high load situations occur except for a throttle blip? say, 1500 rpm uphill. or 2k rpm level ground w/ ac on. just a rattle that i can't quite seem to place with VCM scanner, doesn't bring on KR in the logs but it damned sure isn't supposed to do that!! I want the engine to run well again!!! lol.. HELP! |
© 2024 MH Sub I, LLC dba Internet Brands
