Anyone played with Injector Timing?
I'm hoping for some much nicer VE tuning sessions this time, because before, I could never really find a happy medium in a few areas.
Wish I knew what the values in HP Tunners ment long ago. The custom PCM we are using on our project has that table defined in degrees of crankshaft rotation from 360 to -360 so it is much easier to understand then the way GM did it. Now we know so I bet the tunes will get even better.
I moved to Odessa and have not yet changed my location. Back in Texas were I am from
.That is actually one of the smaller engines we use in the Gas Compression Fields. 10" bores and 10.5" strokes in a straight 8 cylinder config, we have some that are the same bore and stroke but in a V16 config. Up to 4500hp at 900rpm. The old iron from the 40's are what we call slow speed 2 stroke engines, with 14" bores and 14" strokes, running 300rpm, making over 2000hp. Pig Iron!
1) In the spreadsheet, it calculates Shifted/Actual EVC/IVO/ISP EVC/ISP IVO. You take the difference between one of these values and your warm normal value and add/subtract it to the entire normal/makeup tables. So if that new value is 5.55, and the old value is 4.55 when the engine is warm, you add 1 to the entire table... is that correct? If so, which of those 8 calculated values do you use?
2) Does it matter whether you use seat or .050 timing? Does the spreadsheet give correct results with either timing method?
2. I'm not sure what the difference would be using seat vs @.050 timing. I've always used the @.050 data. Maybe one of the other guys would be able to clarify that.
-784 + ((Boundary + Normal) * 90)
This gives the End Of Injection Timing in crank degrees ATDC compression stroke in a 720* engine cycle. Factory fbody values gives an EOIT of ~300*
There is alot of people's interpretation of this in his thread over on HPT forum's but you can sift through the posts and get an idea of what needs to be done and experiement to find the best results!
http://www.hptuners.com/forum/showth...highlight=EOIT
I do not feel I have figured out much about EOIT after all, except that it would be best if one could increase EOIT with RPM from 1500 through 4000 RPM as some after market PCMs allow one to do. This way you can move up the injection timing for a better idle without hurting WOT performance.
I did learn that filtering MAF above 400 RPM for dynamic air computations in my PCM instead of above 4000 RPM seems to give me a lot more steady AFR at various MAPs and throttle positions and a much steadier cold start idle.
