Instant start up rich? First few seconds.
I messed with the cranking VE... no affect.
I changed the Afterstart enrichment "Initial adder vs. ECT" table, multiplied it by 75% and it got richer, went to 9:1
Wouldnt reducing the number you're multiplying by reduce fuel?
Ive leaned out the VE table there from 400-800 with no affect either.... its the first few seconds im having issues with.
Give it more air to make it start fast and reach like 1000 RPM and slowly decay to preset idle.
Maybe you are seeing a false rich condition and pulling fuel won't help.
What are you using to tune? Post your tune file and a datalog to have more info
You need to modify the airflow tables. There are several tables where you modify the amount of air the engine needs.
I don't have HPT here, but go to idle-idle airflow and on the left you'll see the airflow tables. Raise the values 5% at a time and check
If you have it setup like that, and still need to remove fuel, you can remove it in the cranking fuel tables.
