Diagnose LS1 with a diagnostic tool
Old Jun 3, 2011 | 01:05 AM
needtransam's Avatar
Default Diagnose LS1 with a diagnostic tool
So I want to see what I should look for if I get a diagnosing tool that lets me read the pcm, how can I check for bad injectors, bad tranny shift points, bad timing, bad spark, ect eect????
Old Jun 4, 2011 | 09:59 AM
crainholio's Avatar
EFILive is my favorite, but I haven't tried HPTuners so I can't compare the two.
Code scanners are pretty useless in my opinion.
There are two PIDs for each cylinder you can monitor which tell a lot about the individual cylinder's performance...Misfire Current and Misfire History. Any non-zero data on any of these means you may have a problem such as injector flow variation or ignition system issues.
I also monitor Long Term Fuel Trim data, comparing the two cylinder banks. They should be within 1-2% of each other. Any significant imbalance here is also a potential indicator of trouble.
The "Professional" version also has a spiffy Cylinder Balance Test, which spins the engine idle speed up to a configurable number and freezes the IAC. It then disables each cylinder and measures the drop in RPM. A cylinder that's not putting out will show up clearly.
Old Jun 4, 2011 | 03:06 PM
Old Geezer's Avatar
EFILIVE here, too.
Old Jun 5, 2011 | 10:48 PM
jay_lt4's Avatar
chineese Tech2's are only $1200 brand new and come with candi module and all adapters and power cables
Old Jun 6, 2011 | 10:02 AM
DynoDR's Avatar
Those clones are junk.
Old Jun 6, 2011 | 10:07 AM
jay_lt4's Avatar
i have a real one, but i was considering one if mine ever died,, i talked with a couple people that had them and they said they actually updated them with gm software through tis and they were working fine.
i figured they would be junk,, but who knows.
Old Jun 7, 2011 | 07:28 AM
gofastwclass's Avatar
HP Tuners Pro is pretty darned cool though I've never owned EFIL.
I have to agree with Crain... handheld scanners / tuners are like comparing candles to florescent shop lights, they give a taste of what you need but have lots of limitations when it is time to really get down and dirty.
