Emissions question
Old Feb 28, 2004 | 03:26 AM
CRAWLIN's Avatar
Default Emissions question
What do I need to set the parameters to for emissions? I have o2 heater codes setting and I want to fix this so I can pass emissions OBD2 test. Which do I turn off and still have the test to complete and allow me to pass emissions. It allows you to adjust if the error sets (on/off) and Error Mode (off/MIL on 1st/MIL on 2nd/No MIL light). Which should I change to what?
Thanks,
Tony
Old Feb 28, 2004 | 07:10 PM
felton316's Avatar
I have mine set on 'set SES= On', and 'Error mode=Type X'. It allows the readiness test to be completed.
Old Feb 28, 2004 | 07:16 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Thumbs up
That is exactly right. Or, if you have an older version of Edit (like me) you need to set the 'test' to "on" and the MIL/SES to type X. Same thing as above, the screen just looks a little different for different versions.
Main thing to remember is, if the option is a toggle for "on/off" only, always pick "on". If the option allows you to scroll between Type A, B, C, or X, always pick X to keep the SES light off.
Old Feb 29, 2004 | 09:48 PM
CRAWLIN's Avatar
Thanks alot...appreciate it....!!!!
Tony
