Stand alone pcm in my 98 Vette?
Old Jul 2, 2011 | 06:48 AM
fotoboy's Avatar
Default Stand alone pcm in my 98 Vette?
I am looking to upgrade to a standalone in my car. Is this possible? I love teh ease of tuning w my 67 502 efi bbc that I have a Painless wiring software and mefi4b pcm. (same as MSD software)
Old Jul 2, 2011 | 07:31 AM
edcmat-l1's Avatar
I would do everything I could to keep the OE controller. Standalones in Y bodies can be a real pain. You'll have issues with trying to make everything work with your BCM and the rest of the car. Plus the OE controller can do pretty much everything you want it to do. By the sound of your other thread, the problems you're having probably aren't in the controller itself. They're most likely in the car. And, even if you wanted to swap out the PCM to check it, they're cheap.
Old Jul 2, 2011 | 07:50 AM
fotoboy's Avatar
Ive had mixed response from local pro's on what the issues are. Grounds is the big one, but not sure if teh pcm is just needing to be a newer better faster model.
Old Jul 2, 2011 | 02:33 PM
Pacer Racer's Avatar
Listen to Ed he knows what he's talking about
If you had an F-body I'd tell you to upgrade the PCM but on a Y body you're opening a big can of worms
Old Jul 2, 2011 | 05:30 PM
edcmat-l1's Avatar
Thanks for the props.
FYI You can upgrade PCMs on the Y-bodies too.
