HELP: M-80 like backfires when started cold and..
Old Feb 29, 2004 | 10:00 AM
JC00SS's Avatar
Default HELP: M-80 like backfires when started cold and..
Just took the cover off yesterday and connected the battery. WHen cold my SS backfires once in a while, but it is loud as hell!! Also my main problem is when it is hot started I always get that gurgling/ idle surging crap. Will go roght to idle @900 then drop quickly almost to the point where it sounds like it will die, then back up to 900 again. Usually does it around 2 times. Any ideas?? Last year I did have a scanmaster hooked up for a 2nd gear WOT run and I got a 930mv reading. Too rich?
Old Mar 2, 2004 | 10:42 AM
JC00SS's Avatar
No one has had this problem??
Old Mar 3, 2004 | 12:57 PM
VoodooWS6's Avatar
Probably a timing issue man..I with start with that..
