Wideband sensor
Old Jul 11, 2011 | 05:26 PM
Maroslut2001's Avatar
Default Wideband sensor
Ok guys i have a couple questions... first my exhaust is lts and true duals with spun cats right off the headers.
From what i have been reading the sensor needs to be before the cats, so i will need to put it pretty much in the collector of the header correct?
Should i mount it in the pass. or driver side?
Thank you Jason
Old Jul 11, 2011 | 05:42 PM
bigairboarder44's Avatar
I installed mine on the driver side because I read that cylinder 7 is sometimes known to be leaner than the rest.
Take my advice with a grain of rice though..
Old Jul 11, 2011 | 06:18 PM
I have also heard that and that where i was think but i wanted to get some other peoples info, Thank you!
Old Jul 11, 2011 | 07:50 PM
SSpdDmon's Avatar
If you put the car into open loop to tune it with a WBO2, you can just remove the front NBO2 and run the WB in the normal spot in the collector.
As mentioned above, I prefer the driver's side as it typically runs a little leaner.
