Harness/pcm ??
Old Jul 15, 2011 | 09:16 PM
Fast 2010's Avatar
Default Harness/pcm ??
Putting an LQ4 into a 98 Trans am. Car will be for race only. Procharger, nitrous if it matters. Goal is to eventually be running in the 8's. Question is which harness and pcm should i use ? The one from the LQ4 vehicle or would a Holley or race style combo better suit my needs ? Is a factory pcm gonna limit me in any way ? Thanks in advance.... Sean
Old Jul 19, 2011 | 06:48 AM
Fast 2010's Avatar
No One.....
Old Jul 19, 2011 | 11:16 AM
CalEditor@PCMCalibrators's Avatar
I would run a 2002 PCM for a minimum. If you would like to step it up. You could try a 2003+ 1 meg PCM. I am not sure if you can get a SD tune for a 1 meg PCM.
