e85 afr wot
Old Jul 29, 2011 | 08:39 PM
408lq4's Avatar
Default e85 afr wot
i have a aem e85 Gauge Range 5.7:1-11.9:1 air/fuel ratio. what should it read at wot to make the most power and what should idle read.
Old Jul 29, 2011 | 10:42 PM
Chalky's Avatar
If fuel is really E85, stoich needs to be 9.76 This varies a little depending on article.
Using AFR, figure 8.47 for max lean power, max rich: 6.97.
This equates to 12.5:1 AFR for max rich and 13.2:1 for max lean.
Old Jul 30, 2011 | 12:08 PM
408lq4's Avatar
whats the difference in stoich and lambda? i am new to tuning. i was just going to go by the wide band
Old Jul 30, 2011 | 02:33 PM
Chalky's Avatar
A little difficult to explain. How about telling what changes you made to tune so far to work with e85
Anything done to stoich setting, or PE?
