Need help bypassing vats
Old Jul 29, 2011 | 09:28 PM
LS1 PRE-RUNNER's Avatar
Default Need help bypassing vats
Hi im in a bit of a jam i have an ls1 from an 01' camaro ss and im swapping it into a chevy pre-runner but the thing is i dont have the ecu or the ignition switch with key for vats. Is there a ecu i can buy that wIll eliminate the vats and i can run this with no problem? (im gonna run a ls1 with a th400)
if anyone has any info i would greatly appreciate it thanks.
Old Aug 1, 2011 | 12:00 AM
RWDCelicadude's Avatar
Just buy any LS1 ecu and have the VATS tuned out of it, that way you don't need to worry about the key or anything else. You can have them tune out other things you don't need while they're at it.
