reduced engine power
Old Jul 31, 2011 | 03:26 PM
sslater88's Avatar
Default reduced engine power
i have an 03 cadillac escalade 6.0 AWD. Had alot of problems with it over the last 6 months. At first the alternator went, replaced that and still didnt run right. scanned codes and came up with MAF replaced that and still had problems. scanned it again and it came up as cam position sensor so changed that. Then i got the code for tps so i checked all wires and cleaned the plugs and that went away now it gives the code for throttle actuator I dont have exact code but can get it later when i have my scanner. Then info screen in the truck says Reduced engine power and only revs to around 1500 rpm. I dont want to change out the actuator if thats not going to change it.
My question is... wth is going on with this thing why does it jump from one code to the next and it not be the problem? any input/advice would be greatly appreciated.
i know its no fbody vette gto etc. but out of all the forums ive been on/looked on this is by far the best for good advice/info.
