hesitation question.
Old Aug 13, 2011 | 01:06 AM
bobbyd's Avatar
Default hesitation question.
I have a hesitaion between 50-60mph. at that time i get some KR. between 2-3.
my question is will a bad Maf cause you to have KR? it only happends between 2to3rd gear shift at low rpm so around 50-60mph once you get to 70 it runs like a beast. this is also only under normal throttle. WOT theres no hesitation.
Old Aug 13, 2011 | 07:39 AM
Old Geezer's Avatar
Data log it, and see what comes up???
Old Aug 13, 2011 | 11:17 AM
bobbyd's Avatar
what exactly should i check/log? i got a aeroforce gauge.
missfire shows none on all cylinders. KR it shows some 2-4 or so.
other than that not sure what else to check out. fuel trims?
