Can someone please help me with this code.
Old Aug 26, 2011 | 11:45 PM
99WS6T/A's Avatar
Default Can someone please help me with this code.
My camaro check engine light turned on and I got the trouble code read, and the trouble code was P0420 - Catalyst System Efficiency Below Threshold (Bank 1). I dont know if its the 02 sensor thats the problem or the catalytic converter can some one please help me figure it out.
Old Aug 27, 2011 | 07:38 AM
Old Geezer's Avatar
For starters:
The catalytic converter has an oxygen sensor in front and behind it. When the vehicle is warm and running in closed loop mode, the upstream oxygen sensor waveform reading should fluctuate. The downstream O2 sensor reading should be fairly steady. Typically the P0420 code triggers the Check Engine Light if the readings of the two sensors are similar. This is indicative of (among other things) a converter that is not working as efficiently as it should be (according to specs).
You have a scan tool to check this out??
Old Aug 27, 2011 | 06:08 PM
99WS6T/A's Avatar
i went to autozone and got the code read but they couldnt tell me if it was the cat or the sensor
Old Aug 28, 2011 | 07:48 AM
Old Geezer's Avatar
Lightbulb U need to..
get to a shop that can read the sensors w/ a real scan tool.
How many miles on the car?
Ever had a major tune up?
Is the car modified?
Old Aug 28, 2011 | 08:07 AM
Scott97LT1's Avatar
Well I get the same code i believe ... but I have longtube headers
Old Aug 28, 2011 | 09:20 AM
99WS6T/A's Avatar
No the car is stock and only has 86000 miles in it
