Need 42# Stock injector data
I opened a compare file from a stock 2000 Z28, but pretty much everything is untouched except for flow rate, cutoff RPM (leaving this alone) and PE Eq Ratio (Which will get changed according to what the car wants.
What should I be running for the 42# Flow rate KPA Data? I have a spreadsheet of a bunch of different injectors but I don't want to imput the wrong data and end up chasing a problem because of it.
Here's what I have NOW.
And the attached image is of the Ford 39# injectors that are supposed to be similar. Ideas?? And I changed the Minimum pulsewidth to 0.8ms due to the larger injector, it will prolly be too much fuel at idle. Ok idea?
Your best bet
Is adjust the flow rate and call it a day.
Bake all the error into the ve and maf if you are running one.
You could tinker with the data and see if you can get it better.
Anyway.. Don't mind the VE mess from the last hack tuner. I haven't gotten around to fixing it. My damn LC1 wont show up and I can't figure out why.
Thanks dude! I converted it to g/sec.
