cluster help !!!
Old Sep 4, 2011 | 10:16 PM
GecZ28's Avatar
Default cluster help !!!
im a newbie to the site and im trying to find some info for my swap.
heres what i have and what im working with
i have an 88 iroc, i removed all the stock wiring, im using a painless universal harness, engine is a simple carbd 350, i swap the dash/interior from a 99 camaro.
heres my ?'s
some of the 99 gauges are class 2 data which comes from the bcm/pcm. can i just wire the gauges up to my sensors/senders and will they work?? if they have to be hooked up to the bcm/pcm, am i able to use the bcm/pcm and just use the wires i need and will that work?
is there anyway im able to use the 99 gauges???
any info would greatly be appreciated !!!!
mike
Old Sep 5, 2011 | 07:42 AM
edcmat-l1's Avatar
No..........
