Can EFILive remove the speed limiter?
I have the AutoTap cable, if EFILive cant do it can I buy LS1Edit that can use the same hardware?
Dan.
I don't know what the export speed limiters are set for, but if you can get to 140, that's probablly indicative of a 160MPH limiter (163MPH = 260Kmh) - when you say "won't do anymore" do you mean the engine cuts out (RPM DROPS) or there doesn't seem to be any more power, with no change in RPM (and sound) of engine?
