on board monitor test $07 and $0C
Old Sep 12, 2011 | 10:22 AM
jak2908's Avatar
Default on board monitor test $07 and $0C
i was playing around on my scanner and found out that both of these failed, can anyone tell me what that means????
Old Sep 15, 2011 | 04:52 PM
joecar's Avatar
Which year/model/vehicle...?
Old Sep 15, 2011 | 05:02 PM
jak2908's Avatar
2000 z28 auto
Old Sep 16, 2011 | 04:46 PM
joecar's Avatar
I don't see monitor MID $07...
MID $0C is catalyst efficiency.
MID $0C TID $70 is catalyst efficiency bank 2.
MID $0C TID $60 is catalyst efficiency bank 1.
[ MID = monitor id; TID = test id; each monitor has several tests ]
Old Sep 16, 2011 | 05:07 PM
jak2908's Avatar
Thanks! Now what would cause it to fail thousands of times?
Old Sep 16, 2011 | 08:20 PM
joecar's Avatar
Degraded catalyst efficiency... i.e. catalyst starts "passing thru", so rear O2 response is too quick wrt front O2.
joecar's Avatar
What scanner do you have...?
Old Sep 17, 2011 | 08:18 AM
jak2908's Avatar
it is a Launch Creader V
Old Nov 15, 2021 | 07:58 PM
WildAngel's Avatar
Default No start, just spark
Mine throws that code too but won't start on a 98 chevy silverado 5.7 replaced fuel pump, regulator, plenum, spark plugs, wires, spider , sensors, still won't start . turns over, back fires when using starting fluid, any ideas?? I don't know what else to do
Old Nov 15, 2021 | 08:02 PM
Hopefully someone will chime in. You replied to a ten-year old thread.
Old Nov 16, 2021 | 05:46 PM
joecar's Avatar
You have a separate problem, you need to check for presence of fuel, spark and air and you need to see if the MAF, MAP, IAT andECT sensors are returning suitable signal values. Additionally you need to see if the CKP and CMP sensors are returning suitable matching signals. The GM service manual has a very good procedure for troubleshhoting no stsrt problems.
Also check that the exhaust is not clogged (i.e. catalysts causing blockage).
