HELP.. TSP 100mm MAF Calibration.
Old Sep 17, 2011 | 11:03 AM
iMpoSStoR's Avatar
Default HELP.. TSP 100mm MAF Calibration.
does anyone have the maf calibration for the tsp 100mm maf? for a 2002 trans am.. searched everywhere and havent been able to find it.. thanx
Old Sep 17, 2011 | 12:55 PM
TraMotorsports's Avatar
what exactly are you trying to acomplish? MAF calibrations change from vehicle to vehicle regardless of the brand or size.
Old Sep 17, 2011 | 12:56 PM
n20kid's Avatar
Alls i do is just start it up with the wideband, and make my corrections off of that... Easy as pie.. Unless u dont have a wideband... I have a file from a customers car that i believe he had it already flashed in but im not sure, He bought the motor and pcm from somewere and it camed tuned already, not sure if they "cal" was already in it when they dynoed or not.. Lemme look..
Old Sep 17, 2011 | 01:04 PM
of course you can probably find something close to what you've got and the start your calibrating from that point
Old Sep 17, 2011 | 01:12 PM
n20kid's Avatar
This is what was in his PCM as he recieved everything, keep in mind this was a 1999 camaro with a 408 that was tuned on the dyno with prolly a BS3 system and this table was prolly just a base file that was fed into the pcm before shipment and was "suppose" to be already calibrated for the mass air, i compared these number's to a stock file from a 99 camaro and these are much larger and is worth a shot... These are the number's starting at 1500hz working from left to right and then down to the next row...
First cell 1500hz --> 0.4206 0.4733 0.5343 0.6045 0.6852 0.7751 0.8774 0.9910 1.1161 1.2566 1.4085 1.5770 1.7609 1.9594 2.1743 2.4089 2.6590 2.9287 3.2181 3.5260 3.8557 4.2081 4.5811 4.9759 5.3955 5.8388 6.3069 6.7999 7.3187 7.8653 8.4389 9.0414 9.6717 10.3321 11.0224 11.7437 12.4961 13.2815 14.0999 14.9504 15.8361 16.7569 17.7128 18.7048 19.7341 20.8006 21.9064 23.0504 24.2347 25.4582 26.7242 28.0304 29.3790 30.7721 32.2064 33.6884 35.2137 36.7834 38.4018 40.0666 41.7790 43.5389 45.3505 47.2096 49.1204 51.0818 53.0949 55.1597 57.2792 59.4525 61.6795 63.9623 66.3009 67.7250 67.7250 67.7250 67.7250 67.7250 67.7250 67.7250 67.7250 67.7250 67.7250 67.7250 67.7250 <--Last cell 12000hz
