P code and Idle/IAC help
Old Oct 27, 2011 | 04:45 PM
64nova_wagon's Avatar
Default P code and Idle/IAC help
So this is vague. I get it, but im currently away from home till Jan. I was back home in July and my 2002 Ws6 had a ses on. I cant remember the p code but seem to remember it being low voltage iac. I replaced the iac and tps thinking it was that and a day later the ses came on. Same code. Maf is clean. Now I have noticed this whole time that the idle is somewhat high...... (1200-1400) at the first start and then warmed up and when im in neutral and coasting to a stop. Then after 4 seconds the idle comes back to 800. I dont know if there is a minor pvc leak or if its a tune issue. I bought the car late last year from a total tool bag. He claimed it has a gm hotcam and tune. So Im lost. Should I try to get a new tune or do you think its a leak? Car also is somewhat harder to start with an hot soaked engine. Like if I go to walmart and come back. Cranks for 8 seconds then starts and puffs a little smoke. Dont know if tune related either? It seems I can turn the key on, then off and then on and it starts ok? So with 66K i hope its not a fuel pump/reg issue. I need your suggestions on the possible issue
Old Jan 4, 2012 | 05:35 AM
thanks guys., thanks
