Question about SD tunes
Old Oct 27, 2011 | 07:39 PM
95FbFormula's Avatar
Default Question about SD tunes
I have a turbo build in progress but am wondering about the tune I want to go SD but are most SD tuners able to send a baseline tune to get it started and safley driving reason I ask is I would like to be able to make sure i dont have any other problems before taking out to be dyno tuned
Thx for any input
Old Oct 27, 2011 | 08:07 PM
PAT-WS6's Avatar
what injectors?
bayer-z28's Avatar
SD will work, depending on how much boost you will be pushing. I'm running it on my N/A h/c car and I'm thinking about going back to MAF. Higher boost numbers will be a bit more tricky to find a maf to reach the higher frequencies, IIRC. MAF+MAP Transient will always be more efficient and a better way to meter air, but everyone has an opinion on this. But the MAP and MAF pro's and cons compliment each other quite nicely. MAF is good for higher RPM's and faster air speeds, but the MAP preforms well at lower RPM's, so it's a very nice tradeoff.
And correct me if I'm wrong here, by all means..
PAT-WS6's Avatar
need alot more info
Old Oct 27, 2011 | 11:25 PM
sry it is a basicaly stock lq4 ls1 intake single tc76 60# injectors 50mm bov 38mm gate 4l60e trans stock rear gears 273 dual walbro 255 pump running a hobbs switch set to 10psi boost will be 8 to 10 for dd and 12 with maybe a little meth I'm pretty much set on the sd tune just wondering if about being able to get a base sd tune to get it running or if would have to go straight to the tuner for first start up
Old Oct 28, 2011 | 05:49 PM
BLK02WS6's Avatar
Depends on your tuner... some can do it, some can't. How are you going to get the base tune into the car - do you have software? Gonna send them the PCM so they can load the tune in? You gotta find a specific tuner to answer your question - it is possible though...
Old Oct 28, 2011 | 09:42 PM
Using hptuners thx for the replys I got found my answer just wanted to know but to expect after reading somewere that it coulnt be done but found it can be atleast a decent start up tune
