Current applied to MIL PIN
Old Nov 13, 2011 | 12:35 PM
jamiesls1's Avatar
Default Current applied to MIL PIN
How much current (voltage as well if you know) does the mil pin on the pcm support? I am doing a project and need to use a relay but I dont want to destroy the pcm by running to much current through that circuit back to the ground that the mil pin on the pcm applys.
Old Nov 13, 2011 | 02:04 PM
sreve's Avatar
Ignition voltage 12v feeds the logic to the LED MIL.
LEDs are 1.5v and do not draw squat.
Would the PCM driver support a 194 or 1895 bulb? I don't know for sure but
I'm getting 411s cheap enough I might just try it.
Surely someone in conversions\hybreds has done this
