Blown fuse problem
Old Nov 23, 2011 | 10:25 AM
sahwan's Avatar
Default Blown fuse problem
I got 2001 camaro I'm facing electrical problem in fuse called ENG SEN 20 amp everytime I Put a new fuse it get blown as soon as I turn the ignition on I toke the car to electrician he told me there is a problem in one of the sensors but don't know what to do
Old Nov 23, 2011 | 05:54 PM
sahwan's Avatar
Anybody here??
Old Nov 23, 2011 | 08:44 PM
joecar's Avatar
Sounds like O2 sensor wiring melted and shorting to exhaust.
Old Nov 24, 2011 | 02:35 AM
sahwan's Avatar
I canceled the o2 sensor and removed the wiring
That fuse connect with what??
Old Nov 24, 2011 | 08:12 AM
sahwan's Avatar
Now I remove engine wiring and ecu it still blown
Old Nov 24, 2011 | 09:22 AM
JaYZeig's Avatar
looks like youve possibly got a shorted wire somewhere..id start loooking at your wire loom and see where it looks to be rubbed through.
Old Nov 24, 2011 | 05:31 PM
sahwan's Avatar
I hate electrical things
Old Nov 26, 2011 | 10:38 AM
sahwan's Avatar
I can't find the problem
 Michael S. Palmer
Old Nov 26, 2011 | 03:26 PM
joecar's Avatar
Default ENG SEN fuse
You need an electrical circuit diagram...
Attached Thumbnails Blown fuse problem-700033.gif   Blown fuse problem-700034.gif   Blown fuse problem-700052.gif   Blown fuse problem-700053.gif
Old Nov 27, 2011 | 09:08 AM
2TR's Avatar
2TR
+ a GM Certified Electrician.
Old Nov 28, 2011 | 01:30 PM
Reaperchild's Avatar
Question
Originally Posted by sahwan
I got 2001 camaro I'm facing electrical problem in fuse called ENG SEN 20 amp every time I Put a new fuse it get blown as soon as I turn the ignition on I toke the car to electrician he told me there is a problem in one of the sensors but don't know what to do
Alright people ... This is a forced induction turbo weekend warrior. This issue popped up recently when the bottom fuse box under the hood (first yellow fuse 20 amp on the Top left corner ENG SEN) now we tried following the wires on the other end but unfortunately its a circuit to circuit wiring that led us nowhere.
Our major problem is this damn FUSE Blowing on every time we turn the switch to ON (not start up even) =s.
P0102 low input circuit mass air flow sensor error on our scanner.
We know its an electrical fault but there is a confusion because we plugged out the ECU/PCM .. & the wiring is out of the car & it still blows off =s
Old Nov 28, 2011 | 03:39 PM
I hope the mods please move this topic to the appropriate forum.
Thank You
