th400 tune question
Old Dec 1, 2011 | 04:00 PM
dubrado's Avatar
Default th400 tune question
If I keep the auto tune and just delete the dtcs after the swap, can i pass emissions ?
If i swith to a manual tune, will i pass emissions?
Thanks, we have emissions testing in Austin and wanna make sue when they plug into my obdII port ill pass
Old Dec 1, 2011 | 10:44 PM
soundengineer's Avatar
set all the trans codes to "No error Reported" and make sure to leave the SES checked(enabled)
That way all the trans tests happen, and are passed immediately with "no error reported"
though, I believe that trans stuff is not emissions related, so it may not be necessary anyways.
Old Dec 2, 2011 | 06:55 AM
dubrado's Avatar
thanks, I appreciate it
Old Dec 2, 2011 | 07:07 AM
MontecarloDrag's Avatar
Remember to drive the car for a while, because the readiness test take some driving time to be set to PASS
After you tune it, drive it for a day or two, then scan it to check no DTCs are set, because any DTC will make the car fail, and if you erase DTCs the readiness test are also reset and you have to drive it again.
