Why is my motor running lean
Today I pulled the the throttle body off and adjusted the set screw to allow more airflow at idle. I pulled off the IAT sensor, TPS sensor and the harness for the IAC motor. I then cycled the key to reset my TPS sensor to 0. I then plugged everything back. I tried to start my car and it barely stayed alive, my wideband was reading 18:1 and it was misfiring. I put everything back the way it was when I had it running, reset the TPS sensor again (it would read 0 in HP Tuners) and then tried again. I could barely get the engine started and it ran super lean then died.
I checked my fuel pressure which was 60 psi and I know the tune worked before. Does anyone have any ideas of what could be the problem? Think it might be related to the TPS?
It could have nothing to do with the TPS, it was just something I was adjusting before the car ran like crap.
