Switching from SD Closed Loop to SD Open Loop Questions!
Old Dec 13, 2011 | 01:14 PM
TurboStangJON's Avatar
Default Switching from SD Closed Loop to SD Open Loop Questions!
I'm wanting to switch from SD CL to SD OL so I can eliminate my oxygen sensors and start running race gas. I have access (free) to a bunch of VP C12 an I want to try playing with the timing in order to gain a little more power. It's pretty much a race car at this point and a laptop/innovate wideband stays in the car. I'm just trying to get this stock shortblock LS1 car in the 9's so I'm exhausting every route possible. Can anyone give me steps or tips on how to switch over? I'm using HPTuners.
http://www.youtube.com/watch?v=dGhR0...eature=related
Old Dec 13, 2011 | 02:25 PM
The car has had a SD tune for a year and runs great, drives great, and performs great. The only thing I have changed in the file is the Closed Loop Enable (ECT vs IAT) to the max of 284 degrees so it doesn't go into closed loop. Is there anything else that I need to do?
Old Dec 13, 2011 | 03:38 PM
white01ss's Avatar
Set "Purge Canister Open Loop" - to Enable
Set all the O2 Sensor 1 Engine DTC Processing Enablers to Not Reported to clear the SES light.
You probably already copied "Spark High-Octane Table" to "Spark Low-Octane Table" since you ditched the MAF.
Old Dec 13, 2011 | 06:47 PM
Thank You! I will overlook the tune for that since I'm not the one who tuned the car originally. Fasterproms/Formato tuned the car in SD originally and I haven't needed to mess with it until now.
