BEST Computer Tuner?
HPTuners or EFI LIve
then you have handhelds... they all do the same damn thing as they are each others competitors... EFI LIVE and HPTuners also both have 2 bar, 3 bar custom OS tunes....
This is NOT an editor (like HPTuners or EFIlive), it is for flashing only, you can't change any parameters yourself. We modify the program for your specs, you flash it into the ECM.
The calibration format is encrypted and the software write capability is VIN locked (you can only program a calibration into a module with same VIN).
This is to prevent recycling of one of our custom tunes into unlimited number of ECUs. We can, however, email you serial keys on case-by-case basis for you to change the VIN in an ECM, for $50 each.
We can also provide a factory GM calibration for the given VIN free of charge. So in addition to flashing our custom tunes, you can flash back to stock.
The cost to rent the cable is $50 above the cost of the tune with a $200 deposit on the cable. We refund the $200 when the cable is returned
Supported Vehicles
1996 - 1997 All OBD2 LT1/LT4/L99 Cars
1996 - 2001 Vortec Trucks (4.3/5.0/5.7/7.4L) using OBD2 black box PCM
1999 - 2007* LSx Gen 3 Trucks (4.3/4.8/5.3/6.0/8.1L)
(all trucks with LS1 style P01/P59 PCM)
1997 - 2004 LS1/LS6 Corvette, Camaro, Firebird
1996 - 2005* V6 Buick/Chevy/Oldsmobile/Pontiac (3.1/3.4/3.5/3.8L)
(*big PCM only – 04/05 Grand Prix not supported)
2004 LS1 GTO
2004 - 2005 LS6 Cadillac CTS-V
2002 - 2005 4.2L LL8 Trailblazer, Envoy, Bravada (P10 PCM)
1999 - 2004 Holden using LS1 style P01 PCM
2001 - 2005* LB7 and LLY Duramax 6.6L Turbo Diesel
(*ECM only, Allison TCM not supported)
2006 - 2011 Corvette LS2/LS3/LS7* using E38 ECM
(*LS9 ZR1 using E67 ECM not supported)
2007 - 2011 V8 Trucks/SUV (4.8/5.3/6.0/6.2L) using E38 ECM
2007 - 2011 V6 Trucks/SUV (4.3L) using E37 ECM
2010 - 2011 V8 Camaro using E38 ECM
2008 - 2009 V8 Pontiac G8
2007 - 2011 T42 TCM 4-speed automatics
2007 - 2011 T43 TCM 6-speed automatics
