VE Table Cracked
I think most of the WRX boys are into this type of tuning.
Look at the options on this page and then move to the NEWS section, I think they list US locations in there. http://www.mainlineauto.com.au/products/awddyno/
gameover - personally, I think this thread morphed several times - I learned alot. It answered many questions. I wouldn't know what to do with a "hex editor" if I had one - I'm thankful that you guys have them,.... and more, and know how to use them!
NoGo - You are the MAN! - had to say it.
Pete, thats a great idea, im sure it will prove a point, i may be running the car up on the dyno this saturday, ill let you know.
An example, if scan tools were to output the raw numbers they receive rather than converting into "real" units how would you tune? Would you know that a raw value of 128 for the LTFT meant 0? Or would you know how many degrees of KR is a raw value of 100? Most people are used to seeing a VE table in % that's all this thread is about...
Now my understanding is that it will make tuning easier if you new what the ve values represent, true?
correct me if im wrong
Well you tell me what difference would it make if you had the ve table displayed in miliseconds?
You still have to increase or decrease the numbers to acheive the desired afr, true?
if the ve numbers represented say miligrams of fuel,
and if done your calculations and come up with say 2123 miligrams of fuel which i would add to map 100 2000rpm, according to the calculations the afr should read 12.6:1. i just cant comprehend.Remember Gameover, tuning is just that, tuning. an engine will make power and run smooth if its given what it needs, but if you give it what you think it needs it could all turn pear shaped.
Girch.
Girch.
BTW, putting 2 grams of fuel in each cylinder every time it fires your engine would run for about 5000 revolutions before the tank was empty
I have been logging on a few cars lately and have been making a point to reset the PCM prior to beginning.
Gameover's equation so far is ahead 2-1
I'll post up the results once I get everything in order.
Just to clear things up.
When Binks and I did our test (thanks again Binks) we made a point to reset the computer as well, and it made a slight difference, but nothing dramatic. Gameover's equation was still sick lean.
VE = 3444 * MAF * (273 + IAT)/(MAP * RPM *Displacement)
units:
VE = %
MAF = grams/second
T = Celsius
MAP = kPa
Displacement = liters
Seems to be pretty accurate with the data i've got but i think it'll be better when i switch my granitelli maf back to stock. I got excel to calculate VE for all the points in my log file, now i gotta figure out how to sort it into something useful.
All I can say is "Great work" and "Thanks"!
Does ChrisB's LFA perform these calculations correctly, or has someone else created an Excel/Access solution?
I just got a new engine and I need to re-tune it. Not sure if it's worth it to adjust the Main VE or just do it the old fashioned way.
I think ChrisB's LFA provides a "close enough" calculated value to be useful. The main areas where VE changes seem to help are idle tuning for H/C setups and midrange/cruise tuning for drivability. You would still use the common techniques for tuning fuel trims and WOT.
What are the driving symptoms of a VE% which is too high or too low? If I've already tweaked IFR to get my LTFT's to 0 @ WOT, do I need to re-address the IFR table after altering Main VE?
I think you would be safe using 2900 = 100% VE based on data from NoGo and others. Many folks have been using 3000 for a while now with no reports of bad effects.
joel
