TPS won't reset to 0%
Old Dec 30, 2011 | 11:20 PM
ls1jaguar's Avatar
Also when i unplug the TSP the idle will drop too 800-850 which is right where its suppose to be, with it plugged it reads over a 1000 RPM
Old Dec 30, 2011 | 11:33 PM
2xLS1's Avatar
Originally Posted by ls1jaguar
When u say key on engine off u refer to key in the run position engine off right?!?!?!?
Correct
As robust as these PCMs seem to be I would almost say to try a different one at this point just to eliminate that possibility. Although that is easy for me to do because I have full model year licences on almost everything 96-07 MY so it doesn't cost me anything to license another PCM.
Old Dec 30, 2011 | 11:49 PM
ls1jaguar's Avatar
That is sick man!! I'll see if i can get my hands on some used once online!
Old Dec 31, 2011 | 04:42 AM
CashDudeHomie's Avatar
I had a similar problem and had to replace the connector because the pins inside were bent and not making the best contact. There is an updated part that keeps stress off the pins.
An easy way to check this would be to gently jiggle the connector when it's plugged in and see if the reading goes erratic.
Mine would show 7% at idle, but 0% when powered off. Why? I have no idea. But it works perfectly now and no more 1000rpm idle.
Old Dec 31, 2011 | 12:01 PM
ls1jaguar's Avatar
Ok I wiggled the connector, no change at all, time for a new PCM I guess!
Old Dec 31, 2011 | 12:08 PM
2xLS1's Avatar
Are you sure you don't have a weak throttle body return spring and the manifold vacuum is not pulling the blade open a little? Just a thought. But you would probably see that in a greater change in the TPS output voltage if that was happening.
Old Dec 31, 2011 | 05:50 PM
ls1jaguar's Avatar
2xLS1 thank you for ur help, it was a grounding issue, after trying everything I foun out that when I did this engine swap I never ground the PCM's 4 grounds properly, car runs good and stays at 0.0% or 0.4% which is right where it's suppose to be, again thanks for ur help!!
Old Dec 31, 2011 | 05:51 PM
ls1jaguar's Avatar
Ok guys finally after chasing this TPS problem, I found what was wrong with it, my PCM wasn't grounded properly, if anybody did a swap and has this problem make sure all you're PCM grounds are grounded to the good ground, my engine came out of 2000 TA and ground pins are on the blue connector #1 and #40, on the red connector are also #1 and #40, thank you guys all for the help I really appreciated, now I can get my car tuned and enjoy my 383 Stroker!!!!! :-)))
Old Mar 8, 2017 | 12:12 AM
96famaro's Avatar
From: Weatherford Tx 76085 corner of N. Hwy 51 and 150 Green branch Rd.
Thanks guys who chimed in to help. Got same problem with mine and about to tackle it on. This is on an LTX 24x conversion which is same pcm. I was going to try running new grounds anyways. Reading this just confims that it is the best step to take on it first. Thanks for replying back with good results.
Old May 10, 2017 | 11:15 AM
5.7stroker's Avatar
I'm having the same issue.
In HP tuners while at idle:
Throttle pos sensor: 0.73v
Throttle desired position: 0.6%
Throttle position SAE: 0.4%
Idle Air control position 35
Idle Air control desired position 32
Already tried the TPS reset.
Where on the car are the 4 specific grounds to the PCM. I can check for good ground right at the pins on the ecm, but where are the specific points on the chassis?
#1: Back of passenger side cylinder head.
#2: Passenger side of block.
#3: 3 ground wires on the back of the drivers side head.
#4: under the bracket for the air box assembly. (can cause all kinds of light problems)
#5: cluster of ground wires on the lower ds pillar, close to the door pushbutton for the interior light.
#6: Grounding strap from just behind alternator. (PS fluid just loves to reek havoc in that area)
Old May 10, 2017 | 01:28 PM
5.7stroker's Avatar
I'm getting 0.71v at 0.4% on TPS when closed and 4.53v at 100% when TB is fully open at 90 degrees, both by pedal and by moving TB by hand.
After resetting the TPS, it goes to 0v but then goes right back to 0.4% as soon as the car is started.
I checked the tps wires on the harness tps harness itself, an I get the 0.73v and 4.55v. With the car off, and tps harness unplugged, the ground wiring on the harness has 0 resistance. When the car is in run pos with engine off, that same ground wire shows 0.014 resistance. This is with black lead on the multi connected direct to battery. When cranking to put load, it shows 0.100 - 0.200 resistance.
I checked pins 1 and 40 on both ecm harnesses and the resistance is 0 with the car turned off. This is with black lead connected to battery and red lead connected to a paperclip shoved into the red/blue ecm harness holes.
I want to get the tps to read 0%.
Speed density tune, PTM 92mm TB, has small hole drilled into it.
If I try to turn the set screw, voltage at say 0.55v causes TPS to be at 3.0%. Going back to 0.73v on the set screw the best I can get the TPS while car is running is 0.4%, and this is with resetting the TPS properly back to 0 after adjustments.
Old Apr 25, 2025 | 06:23 AM
  #32
nastyiroc's Avatar
Ever get it to read perfectly 0?
Old Apr 25, 2025 | 06:43 AM
  #33
5.7stroker's Avatar
Yes it turned out to be a bad throttle cable. I replaced the cable with 12565560 and got rid of cruise control and traction control.
