2010 Camaro VSS issue (ideas?)
Old Jan 8, 2012 | 02:12 PM
DietCoke's Avatar
Default 2010 Camaro VSS issue (ideas?)
Trying to get speedometer to work in 4l80 conversion. Using optishift standalone, which has a 0-5v square wave output for VSS.
I have it wired to the VSS hi on the pcm, but it isn't reading anything. (There is a vss hi and low wire)
Is there anything else I need to do to make this vss style work with the factory pcm? Ground the lo wire? Wire the signal out to both wires? I don't even know where to start. Car runs/drives fine, tach works, etc. Just no speedo, since no VSS input. Help.
Old Jan 8, 2012 | 03:24 PM
DietCoke's Avatar
Dumb solution: There are two identical gray/black wires in the harness. I simply had the optishift out going to the wrong grey/black wire. Works fine now, with VSS simulated output set to 0.410 pulses. Cheers
Old Jan 8, 2012 | 04:27 PM
Rhino79's Avatar
Hows it feel on the street?
Old Jan 8, 2012 | 04:44 PM
DietCoke's Avatar
Drives great, even untuned. I couldn't be happier. Big stall eats up all the bad manners of a huge engine/cam/compression. Can't wait to get to the tuner
